LeeElms
I'm confused between the various types of insulation available, as to which is most cost effective. I plan to use it behind plasterboard on 3x2 CLS timber framework filling in between the double thickness piers. I also plan to insulate above the plasterboard ceiling.
So, hoping for simple advice as to how to provide a reasonable amount of insulation for a reasonable cost.
My confusion is due to the range of insulation products available, and because when I tried to understand the various U values and prices, it appeared that Celotex, which I had assumed was a relatively expensive option, was cheaper than Rockwool (for the same insulation value). Another consideration (just to complicate things) is which option is better for sound insulation -- although, in respect of both the heat and sound insulation I realise that what I do with the garage door is a signficant factor.
