Installation advice
Popshw
24 Feb 2019
Andover
Can anyone advise on the best method of hanging these.
I have got two to install, fitted flush to the ceiling and flush to the wall either side of the room. One side is an exterior wall and can be secured to brickwork and ceiling joists above.
However, as shown in the other image, the other side has the same ceiling joists however, the wall stud is 400mm from the corner and the shelving is 260mm deep and therefore, cannot be secured to that stud.
Shelving is 1000mm x 960mm x 260mm - made from 22mm MDF and a 9mm back panel - so fairly heavy.
Planned to use a French cleat but with it needing to be installed flush with the ceiling this is not possible.
Not really used to many plasterboard fixing styles so any advice on whether these would be suitable?
TIA
Not a 100% sure on what you are describing but have thought about placing it on a timber bearer fixed to the studs, with the top fixed to the wall.
