jonny boy
What adverse effect can setting the amperage dial in the starter have on the motor then?
jon.
jon.
herdsman":1mlzpnxr said:Surely the overload relay reacts to temperature thta's why they are known as 'thermal overload relays'? The bi-metal strips inside heat up as the current increases and bend due to the temperature increase causing the trip mechanism to operate.
jonny boy":2724s83g said:Bob, I have tried it when the starter is set on 12 just over. It say's inside the starter cover, do not exeed the FL amperage of the motor or motor burnout could occur. I dont want to risk that.
jon.
9fingers":1hr4xkbp said:herdsman":1hr4xkbp said:Surely the overload relay reacts to temperature thta's why they are known as 'thermal overload relays'? The bi-metal strips inside heat up as the current increases and bend due to the temperature increase causing the trip mechanism to operate.
NO, Thermal overload relays use a thermal method to integrate the current. The trip mechanism has absolutely nothing what so ever to do with the temperature of the motor.
How can it when they are separated by a length of cable?
Bob
jonny boy":3ouz199x said:Fair comment Bob, I have an extractor that only has a two horse motor and in that starter, the dial is set at 17 amps, that was set by Axminster and has never tripped in two years. Are you fairly certain I could raise the dial in the saw's starter then?
jon.
jonny boy":1wd4pvso said:Fair comment Bob, I have an extractor that only has a two horse motor and in that starter, the dial is set at 17 amps, that was set by Axminster and has never tripped in two years. Are you fairly certain I could raise the dial in the saw's starter then?
jon.
herdsman":1zrzrgj5 said:9fingers":1zrzrgj5 said:herdsman":1zrzrgj5 said:Surely the overload relay reacts to temperature thta's why they are known as 'thermal overload relays'? The bi-metal strips inside heat up as the current increases and bend due to the temperature increase causing the trip mechanism to operate.
Bob
The voltage supplying the motor must first pass through the themal relay otherwise the motor will not be protected, I agree that the temperature of the motor does not operate the trip but the currect that is drwan by the motor will also pass through the thermal relay. The cables from the supply to the motor are part of the same cirucuit and therefore it is not separate.
9fingers":1t7nd3m9 said:herdsman":1t7nd3m9 said:9fingers":1t7nd3m9 said:herdsman":1t7nd3m9 said:Surely the overload relay reacts to temperature thta's why they are known as 'thermal overload relays'? The bi-metal strips inside heat up as the current increases and bend due to the temperature increase causing the trip mechanism to operate.
Bob
Herdsman: please note that I said the motor and thermal relays were separated BY a cable not that the cable was separate.
Voltages do not pass through relays - currents pass through things and current is what the overload relay measures.
Bob
jonny boy":1ucp4uce said:Herdsman, How is it then, that on the saw plate, it say's the motor is rated at 12.4 amps. Or is this NOT the full load amperage?
jon.
jonny boy":qcewzx8z said:I do appreciate all the members taking the time to follow this thread.
jon.
herdsman":r2zu8hvi said:Bob, you are earning your supper tonight!
