A
Anonymous
Guest
Further to my post on page 2 advocating the dozenal numerical system and David C's post I have just ordered a Bobsrule - sounds like the answer to me!
Brad
Brad
Brad Naylor":18126lhi said:Further to my post on page 2 advocating the dozenal numerical system and David C's post I have just ordered a Bobsrule - sounds like the answer to me!
Brad
Is a counterfeit one a guinea-foul?Paul Chapman":1zg461yl said:Ah guineas - always seemed to add a bit of class 8) 8)
Paul
Ah hah, you see that's why metric is ultimately doomed - decimal people go round in tens while imperialists go round by the dozen and can overwhelm them with superior numbers. :lol: :wink:senior":114b05rq said:Tombo, don't let the power of the dark side tempt you, use the force and venture forth with the decimal people.
Alf":10phxe1i said:Ah hah, you see that's why metric is ultimately doomed - decimal people go round in tens while imperialists go round by the dozen and can overwhelm them with superior numbers. :lol: :wink:senior":10phxe1i said:Tombo, don't let the power of the dark side tempt you, use the force and venture forth with the decimal people.
Cheers, Alf
Vormulac":24p5rx5m said:... I mean seriously, what's easier, looking at something and realising you want an 8mm drill bit, or a sixteen and three quarter sixty fourths drill bit? Obviously you prefer the system you grew up with, but anyone who can objectively say the latter in the example above is clearly not well. :lol: ...
That does make me laugh (in a good way, Mr Spanton), it clearly comes down to what everyone says about the best system being one that suits you; but the concept that measurements based on 1/32ths or 1/64ths of something are somehow less abstract than a denary system (the basis of our numerical system for hundreds of years) I find rather odd.mr spanton":269miyfj said:FWIW :roll:
I have tried, really I have to get on with metric, but it is too abstract,
CAD programs and CNC machines can easily accommodate any mearurement system you like, so long as there is a values conversion factor. The only downside is that CAD and CNCs tend to like decimal everything, e.g. 1,03in 3.55mm, etc - even BobCAD - bot that's because it's much quicker th key-in decimals IMHOShivers":22rmmki9 said:.....then the translation is going to be horrendous.imagine programing machines for this if the product design comes in already made out in either of the former,
It'll be a hard job also getting cad programs to adopt this as an alternative because engineers/designers/architechs aren't woodworkers so there will be no emphasis on bobcad.
Scrit":139itynv said:I sidestep the issue a lot of the time by simply using a rod........ no measurement system at all :lol:
Scrit
Shivers":1d7wnry2 said:Brad Naylor":1d7wnry2 said:Further to my post on page 2 advocating the dozenal numerical system and David C's post I have just ordered a Bobsrule - sounds like the answer to me!
Brad
hey brad that is a good system,& should be excellent for your own work,but if for instance you have to copy something made in metric/imperial,---or work off designer/architech plans then the translation is going to be horrendous.imagine programing machines for this if the product design comes in already made out in either of the former,
Another one would be contracting work from builders,you'd be sure to get some sideways glances if bob is mentioned,
It is a good system--but alas not transfereable across all trades/disciplines.
regards
shivers.
mr spanton":29lgjfca said:FWIW :roll:
I have tried, really I have to get on with metric, but it is too abstract, the system doesnt help you by relating measurement to the actual physical scale of the world around you in useful increment's or units. to make any sense of metric I STILL have to break up a metre say into smaller more useful units (or fraction's) that I can relate to the physical world about me for comparison.
mr spanton":29lgjfca said:I certainly do resent the metricalisation which is being imposed for no good reason other than to establish enforced global collectivism and keep beauracrat's busy. I'd feel exactly the same if inche's/cubitts/cun's etc were being imposed the same way. I wouldnt object to mini meter's if I had a CHOICE as to wether I wanted to use them, or not as the case may be.
mr spanton":29lgjfca said:Now the beauracrat's are telling us their metric system is "superior" And sadly lots of people believe it .
CYC":2rfbcdb7 said:3/16 + 18/32 = Wait where's my calculator!
promhandicam":3akp0wte said:a 454g jar of jam, Steve
CYC":gk93zhl0 said:I don't know about telling us it's superior, but I believe it's easier to learn. what's easier to understand and learn for a little child:
2+3=5
or
wrightclan":233mpg3g said:CYC":233mpg3g said:I don't know about telling us it's superior, but I believe it's easier to learn. what's easier to understand and learn for a little child:
2+3=5
or
Ok, which is easier:
Divide 5/16 by 5.
or
Divide 8mm by 5?
:wink:
By the way, the correct way to write your above fraction example is:
3/16 + 9/16. Much easier now, isn't it? :-k
Actually, I find this whole idea of equating imperial with fractions and metric with decimals a bit odd. I was taught at school to do maths in decimals and fractions. I was taught to use imperial measurements and metric measurements and to convert between the two. It never occurred to me, until I lived over here and heard widespread usage of terms such as 'decimalisation,' that the metric/imperial debate had anything to do with a fraction/decimal debate. Do they even teach fractions over here anymore. Guess I should ask my kids? :-k
Brad
Adam":qd85dfba said:promhandicam":qd85dfba said:a 454g jar of jam, Steve
Cough, splutter, as we hurdle headlong into an entirely new area of thread.
Adam
