Ideal size and orientation for a workshop
Beau
23 Mar 2015
Devon
OK I am debating what to do in the future and may go back to furniture making for a living. At present I just do the odd job and have rather fallen out of love with the work. On consideration I think it is not so much the work that has put me off but the environment. A small workshop with poor light and high humidity is not the best place to make quality bespoke work. We have outbuildings that are in need of TLC and or re building. Just wonderd what is the ideal sized space for a one man band to build a variety of work. Howe much natural light is required and from what direction? Then there is heating and humidity control to consider especially as we live in the wilds or Dartmoor where external RH can be near 100% for days on end. Should I have separate stores for wood and areas for finishing? I would appreciate advise on the workshop and how to cope with working in a workshop on your own.
Beau
I'm one man making general domestic furniture. The workshop's about 80 square metres split between a concrete floored machine room and a sprung wooden floored bench room. In addition there are two single garages as timber sheds, but I carry far higher timber stocks than most furniture makers need. There's a combination machine in the centre of the machine room, a bandsaw, disc sander, drum sander, drill press, lathe, morticing machine, the extraction system, and a router table. In the bench room there's a sharpening station, a Morso mitre cutter, an MFT table with extension, a bench, a component table, an assembly/veneering table, sash cramp stand, and a log burner.
It works okay, at a pinch I could squeeze in another maker. If I was doing joinery packages it'd be too small, for fitted/kitchen work it'd be way too small if you needed to finish and store multiple completed jobs. I made a conscious decision not to offer sprayed finishes, a couple of times that's caught me out so that might have been a mistake.
A combination machine works okay for a single maker who can schedule all his work in advance. It'd be more difficult with two makers on a permanent basis. Relevant if you ever were to rent out bench space, although the demand for bench space seems to grow exponentially as you get closer to conurbations.
A few makers I know are offering training for paying pupils, if you go that route that's more benches and probably a stricter approach to safety.
Thirty or forty years ago you could comfortably marry furniture making with antique restoration, but antique furniture prices have dropped steadily for about fifteen years now so that's not so easy any more.
It's the same old story, furniture making is a financially marginal occupation. Few people can make it fly on a pure designer/maker basis. If you accept that from the get go (and you've been there so you already know the reality) you'll build in enough flexibility into a workshop design to accommodate a plan B!
One last point, I'm surprised about your comment regarding humidity. I'm on the coast but I don't see RH change all that much during the year. The workshop is double glazed and insulated, but I doubt that makes all that much difference. Certainly the timber sheds are just garages, I'll pull timber into the workshop a few weeks in advance and let it settle, then often machine down in two or three stages. But timber movement after client delivery or during a build is more of an occasional irritant than a major problem.
Good luck!
Thats great Custard.
80m2! can see why I struggle with 35m2 and no other store. Spend my life moving work from A to B and back again to gain access to a machine.
Yes already got a universal and happyish with that.
Don't think I could handle the HSE of sharing or having students. I can barely organise myself let alone another head haha.
Getting the work shouldn't be a problem but probably would have to be flexible but been there before doing everything from building a house, a boat and being a general odd job man. Making a polycarbonate window for a rally car on Monday. Antique restoration just NO. Messed around with this many years ago and loathed it.
Humidity is stupidly high here most of the time. 97% RH at present with thick fog. Just the joys of the first west facing hill the Atlantic weather meets. On the other hand was down at 45% two days ago.
Not committing to going back to it all yet but looking at my options as the body cant handle my current main job for ever.
Good luck!
I'm five miles from the coast and ours varies from 90%+ in the summer to about 55% in the winter.
