That would work":2pledqnb said:Damn it.... I can't think of any more salt hating creatures #-o
You have to make it more relatable. Like a recent heart attack survivor eating steaks soaked on the Bonneville salt flats.
AndyT":3b6iwm4v said:Ok, here's a considered response from me.
If I was earning my keep as a full time woodworker, planing chiselling and sawing all day long, and efficiency was one of my goals, this discussion would matter to me. But I'm not. I'm someone who's happy to spend his time pottering in the workshop/playroom making things out of wood.
I even deliberately reduce efficiency by trying out different approaches - do I prefer using a wooden plane or its metal equivalent? Saw, plane or chisel a rebate? Tails first or pins? Gang cutting or singles? Rip by hand or by bandsaw? Radio 3, 4, or 6? Thing is, I can forget what the answer was before next time I need to know. Never mind!
In all of this, I sometimes try to do fine, careful work - such as my little walnut table - and then, I will be more careful about sharpening. I'll do it more often and I will also hone.
But if I am doing something more undemanding - like planing a piece of wood so it's the right size to mend a hole in the shed - I adjust my standards - so a plane or chisel would just get a quick rub on a fine-ish stone and get on with it. You could call that "sharpening to what's needed for the task" if you like. To me it's more about common sense than any sort of claim to be a superior worker.
I can easily spend more time making coffee or tea than I do sharpening, but I'm not going to stop doing either of those.
Sideways":28rwei5i said:Ignoring all the baggage. I'll listen to someone who's open to trying a new idea that doesn't fit with their own preferences, and willing to change when the facts as they best understand them say they should.
I often pick up a plane or other tool and have a quick go on an offcut just for the pleasure of it but I don't do any tests as such, just go by feel. I'm basically lazy, so even if I've decided to do something all by hand only, I'm continually looking at how to get away with doing it the easiest way, which seems to be the opposite of what a lot people on here do.Trevanion":2ofruc1k said:I think I can hear the rumbling and thundering of a keyboard somewhere in the north, I think everyone should seek shelter.
I'd use a scrub plane. This is exactly what it is for (there's a clue in the name!)D_W":1w1qmifx said:I agree Jacob. In this case, the laziest way ends up being different than what I expected.
The story changes entirely if you use dirty or damaged or contaminated wood. In that case, just plan to sharpen a lot. ....
My sharpening is all about doing it the easiest, quickest and cheapest way - believe it or not!Trevanion":1w1qmifx said:Who are you and what have you done with the real Jacob?
D_W":qwcx0bvt said:Trevanion":qwcx0bvt said:I think I can hear the rumbling and thundering of a keyboard somewhere in the north, I think everyone should seek shelter.
being not from the UK, I can only guess Jacob lives north? :lol:
MikeG.":1fr3sh7c said:I'm not interested in the results, particularly, but I'm interested in the tests. My first degree was a BSc, so the scientific method is a priority for me. At the very least I need to see a properly described method, a hypothesis, an objective set of measurements, falsifiable results/ claims, and repeatability. It would also help if the guy doing the test wasn't an advocate, or if he was, that the tests were at least blinded. The original "foot-planed" test didn't fulfill many of those criteria, particularly the "objective" part. When you can develop an objective test such that there is a measurable point at which the blade is blunt (ie all blades are tested to precisely the same degree of bluntness) then come back to us and let us know. Until then.............meh...........whatever.........
No, sod the client, but presumably you would care if you spent longer than you needed to, or bought kit which didn't pay for itselfthetyreman":uu6c39kn said:whether you're making money from it or not is sort of irrelevant, just use a sharpening method you're happy with and stick with it, if I'm a prospective buyer or client, do you really think I'd care if you took one extra step to sharpen on a 2000 grit stone instead of 1200 then stropping?
Jacob":2bd7g2ki said:No, sod the client, but presumably you would care if you spent longer than you needed to, or bought kit which didn't pay for itselfthetyreman":2bd7g2ki said:whether you're making money from it or not is sort of irrelevant, just use a sharpening method you're happy with and stick with it, if I'm a prospective buyer or client, do you really think I'd care if you took one extra step to sharpen on a 2000 grit stone instead of 1200 then stropping?
thetyreman":3e6p6nce said:whether you're making money from it or not is sort of irrelevant, just use a sharpening method you're happy with and stick with it, if I'm a prospective buyer or client, do you really think I'd care if you took one extra step to sharpen on a 2000 grit stone instead of 1200 then stropping?
AndyT":357b1n41 said:I'm trying to work out why David's efforts are not appreciated as much as they might be. He's gone to considerable effort and expense.
In trying to distil his posts to a couple of simple messages, I think I get to these:
1 - The new "PMV111" steel used by Veritas does keep an edge longer than the carbon steel used for the last 250 years.
2 - Sharpening to a very fine grit is worthwhile - the edge lasts longer and the finish is better.
3 - These differences are not often noticed because
(a) most of us don't hand plane for long periods with frequent sharpenings and
(b) some boards of the same species will blunt an edge much quicker than others.
Is that a fair summary?
AndyT":1ky3jhsj said:I'm trying to work out why David's efforts are not appreciated as much as they might be. He's gone to considerable effort and expense.
D_W":29dew33l said:........My original footage planed test, as described above, satisfied every criteria you listed........
