You must also be removing the waste fitting itself. I have the Armitage Shanks single sink in the utility and the cast in overflow gives me a 1 3/4 bulge round the waste on the underside of the sink, it had to go in before the worktop and I cannot slide it out so I made sure I used really good brassware without ceramic valves to minimise future problems with tap access.My kitchen setup is a copy of the OP, I slide my 'Belfast sink' out after undoing the waste pipe
My double Shaws sink has a flat bottom, really glad about that so I can slide it into place once the taps are fitted. Something worth noting is to always fit full flow isolators on the pipe work that are accessible, sounds obvious but I have seen a job where they were accessible until the sink was fitted !
