Bodrighy
CHJ":3kc1yb2m said:Bodrighy":3kc1yb2m said:...snip.. Result? My lathe whispers, runs really smoothly, better than original.....
...snip..
Well they say it is an ill wind that...
Joking apart Pete, despite having to go through the frustration of having to fix a broken part that is so basic to the operation that it should not have failed even on a machine built to a lower finish standard, the fact that you have been through this learning curve and have a sweeter running headstock is a positive.
Hope the fix does not mean that you have to trade in the sweeter running assembly and can get replacement parts fitted.
If it does you can bet that I will be opening it up, checking everything and lubricating anything that moves, or should move, before I use it :lol:
For years, due to finances and a huge family, I ran old Landrovers that I often had to sort out at the roadside so frustration is something that I have learnt to live with. My main concern is that suddenly I have been asked to run a stall at three different places in the next couple of months and need to build up some stock for them. I have a good supply of wood in so hope that this will get sorted quickly
