How to turn with coloured Resin?
Fat Rich
8 May 2014
Detling, Maidstone, Kent
Treat the same as wood on the whole. There is a couple of thing that you need to be aware of is resin can be very stringy when it comes off the tool and sticks to everything, and some may be a bit brittle so don't rush in take gentle cuts until you get the feel of it.
I use the resin bought in car shops for adding to glassfibre,then add spirit stain or other dye to it,once set i turn it as normal for bowl/spindle turning,the only thing I`ve found is to be careful when sanding as the resin is harder that the wood mostly,cheers,
Eric.
