Im not sure on the laminate, but if it's hard and can cope with the heat / friction if the blade rubs, it should be fine. I simply measured the size of the old one and made a short length of it, so ive probably got enough for 4 pairs.
I have tried over the weekend to set the Kity up using Alex Snodgras method with no luck. I set it by eye and get the tension and blade position as he described. Good so far.
When I turn the saw on the blade instantly moves forward to roughly the position as recommended by Kity with the teeth overhanging the wheel.
Looks like new tyres are required. Any recommendations? Is it a diy job or can anyone recommend a decent place to do it?
It seems the Kity doesn’t have crowned tyres.Those Snodgrass videos are for crowned tires.
Does the Kity have the same?
