Sawyer":gws1e3r1 said:
... but have always wondered if it may encourage the casting to deform.
This had never occured to me, but now I'm curious, since it was mentioned in a post a few months ago. Does raising the toe cause the iron to move? I've never noticed, but I've never measured either.
Chris Schwarz noted in a Youtube video, that I can't find at the moment, that resting the plane on it's side was to protect the blade from metal objects which may be hidden by shavings on the bench and was popularised by woodwork teachers in the mid 20th century. Prior to this, he said there was no reference at all about resting planes on their side. He continued that you should be in control of your working environment and should know where hard objects were on the bench and where it was safe to place a plane. Indeed, he concluded, resting the plane on it's side could cause more damage by leaving the blade exposed to being knocked; on a clean bench, the blade is only resting on wood which will do no damage. I'll try and find the video...
For the record, mine are stored raised slightly to allow air to circulate and help prevent rust, as noted above, but on the bench I just put them down; it's a chunk of metal, not a Fabergé egg... :wink: :mrgreen:
