Interestingly, if you use oilstones, just the small amount of oil that's left on your hands will be enough to keep even the lever cap from rusting. But (and I'm still guilty of this), tools that are sharpened or used seldom won't fare well with that strategy, but neither will their castings or cap irons.If you shine it up and don’t watch out it will rust up again. I would see if there is a chrome shop nearby that rechromes bumpers etc and see what they would charge to slip it in with other work. Might be cheap if for cash or a case/flat of beer especially if you have done all the polishing prep first.
I use it a lot, for cleaning with wire wool, for polishing, preserving etc.
IMO it ranks with duct tape and cable ties as great inventions.
Thanks Steve - very useful.Buff out the lever cap with a medium to soft wire wheel mounted in a drill. That will take the corrosion off and give it somewhat of a clean look. Put several coats of lacquer on top of the trade label to protect it and then use fine sandpaper to clean the rest of the tote. Apply a new coat of stain to your taste and coat with lacquer or shellac. The sole needs a definite clean also on a flat plate such as granite or your table saw. Best of luck to you, from a dedicated Record tool user and collector.
Thanks Fergie,Afraid the chrome is too far gone to save. You could have it replated or take it to a plating shop and get them to remove the chrome, then just buff the bare metal. Steve's idea will certainly bring a big improvement, but still won't look that great IMHO. If you did decide to get it replated then worth remembering that chrome doesn't have to be super shiny, it can be satin or matt. Basically the plating is so thin it will not alter the underlying finish. So if, for example, you fine grit blast a part then chrome it you get matt chrome. You might decide that mirror polished would be out of keeping.
I agree the guy I used to go to was very good and took real care not to overdo it. Unfortunately when he retired the guy who took over polished the life out of the first thing I took him, rounding off what should have been sharp edges and totally wrecking it. Now I take stuff in to be stripped only. I then do the finishing myself and take it back to be replated. Bit of a nuisance but at least I can determine exactly the finish I want. For something like this a slightly satin rather than mirror finish looks much better.I got a bunch of lever caps re-plated for myself and another forum member and felt afterwards that I wish I hadn't. I asked the plater not to go anywhere near them with a linisher, so what did he do? The very shiny and now misshapen lever caps just looked out of place on a vintage tool. Buffing as DW has done is the better way to go IMHO.
Richard
