CNC Paul":14fenhrj said:Dave,
Have a look on ebay http://cgi.ebay.co.uk/SAMSUNG-FRIDGE-CO ... 7C294%3A50
If it is too far ask the seller to put it in a box and use www.parcels2go.com , they collect and deliver.
oddsocks":2hm4vfef said:Much to my surprise my 'Wanted' request on freecycle has already had a response - someone has an unwanted vacuum pump from a printing frame....I'll collect it tonight So I don't think I need to bid on the compressor but it looks a good option for someone.
flh801978":3p8oha2p said:Oddsocks
The unit you have there is off a parker print down frame a very expensive piece of kit when it was new... now sadly obselete with the advent of laser plate setters.
However the pump is useable by itself the timer is to allow time for the vaccuum to build up before exposure starts.
The solenoid with the silver nut on top is to bleed off the vaccuum after exposure has finished to allow you to open the frame...otherwise you would never open it.
Just remove the pump and use the vacuum connection
Ian
I just spoke with Rutlands and they say this will provide a 600mm of Hg. Which equates to 24". According to JoeWoodworker this is adequate for a vacuum pump.Bloonose":prg03rwh said:This has just appeared on the Rutlands website, and seems to be an easy and reasonably cheap way to get started! :wink:
http://www.rutlands.co.uk/cgi-bin/psProdDet.cgi/DK1135
flanajb":q1viv8ey said:I just spoke with Rutlands and they say this will provide a 600mm of Hg. Which equates to 24". According to JoeWoodworker this is adequate for a vacuum pump.Bloonose":q1viv8ey said:This has just appeared on the Rutlands website, and seems to be an easy and reasonably cheap way to get started! :wink:
flanajb":2fmjjqmg said:I just spoke with Rutlands and they say this will provide a 600mm of Hg. Which equates to 24". According to JoeWoodworker this is adequate for a vacuum pump.Bloonose":2fmjjqmg said:This has just appeared on the Rutlands website, and seems to be an easy and reasonably cheap way to get started! :wink:
