Graham N
Just starting on using a vacuum bag for veneering and laminating and would appreciate some advice. I have a large bagpress from Axminster and bought a pump to use with it. I am unsure where to install the bag connector. I have seen two different sets of instructions about where to install the coupling on the bag. One shows the connector installed near the end of the bag, off the veneer, while the other shows it resting on top of the veneer item. I guess that runs the risk of marking the veneer, is that the point? The connector is aluminium as on the attached image
. Any advice for a newbie very much appreciated. Thank you, Graham
