That's the speed of light in free space (vacuum), not the speed of propagation of a signal in a wire.
The speed of light in free space (a vacuum), c, is very close to 300,000,000 m/s, i.e. 30cm/nS or about 11.8"/nS.
Real-world signal propagation speed occurs relative to c, and is defined in terms of relative permittivity, or dielectric constant known as "Er". For the FR4 material used in most common PCB boards, Er ranges from 3.8 to 4.8, depending on the glass weave style, thickness, resin content, and copper foil roughness etc.
The speed of signal propagation in a wire is c/sqrt(Er) where Er is the dielectric constant for the surrounding material.
Therefore, on an FR4 PCB, in 1nS a signal will travel between 13.7 and 15.4cm, i.e. between 5.4 and 6in.
Teflon (PTFE) has an Er of 2.1 (or thereabouts), which means that in 1nS, a signal propagates about 20.7cm.
For comparison, BS6231/Tri-rated cable has a PVC covering with an Er of around 3.2, so in 1nS a signal travels about 16.8cm, i.e. Teflon is FAR superior to PVC as an insulator or substrate at high frequencies.
The Er values for PCB substrates and wire insulation are extremely important at high frequencies where timing is important, so material choice is a critical part of the design process.
