Removed an old laminate floor (downstairs) from my daughters new property which was built in the mid 80's. The property is timber framed. I was a little surprised to find chipboard flooring underneath (expected to find a concrete base). The chipboard has been laid to cover the whole of the downstairs and the walls built over this.
The flooring in general does not seem to have been too well laid - there are some quite large spaces between boards (not enough to reveal what's underneath). Also cannot so far find any evidence of fixing (no nail or screw heads!).
I am intending to replace with new laminate but have found a couple of problems with the chipboard floor and would appreciate some advice and views on quickest way to fix the problems which are:
1. One board in particular has become convex down most of its length. Do not understand how/why this has happened. I did remove a length of telephone extension cable which had been forced down the gap between boards - could this have caused the bowing over time?
2. In the hall there is a definite dip between the end of two boards.
Apart from these issues the floor feels very solid - no bounce etc.
So looking for ways to fix - without trying to relay the whole floor! Original thought was to use self levelling compound which would probably be ok on the floor area that has dipped but would not work on the convex length of board.
Any advice / suggestions much appreciated
Tony
Tony
