Phil Pascoe
I have absolutely no means to pay for a professional electrician ...
So live with things as they are until you have.
Your best bet is a separate ring for the extension, or failing that an unswitched extension to the current ring.
You can't make the switch shown do what you want. To make a correct ring extension you would need to switch both lives and neutrals, but you're well short of both connections and the right changeover pattern for that.
You will need a 4 pole changeover switch to do this. In the "off" position it will have to close the existing ring and isolate both ends of the new one and the "on" position it will have to open the existing ring and connect to each end of the new ring.
