Matt Estlea does a good one too. It is on a slight angle sinuses the whole plane blade rather than the same part over and over b
Sorry. He talks a lot of nonsense in his preamble ramble:
Only a small part of the blade is used in his set up .... "his" design is no different from many others built before him.
Michael Connor was the first one I saw. I built nearly 20 years ago, and have discussed many a time on fori. His attempt to use "all the blade" fails (although there is a way to do this - just not his way). The preamble of his is simply to sell his video. Viewer Beware on YouTube.
I wrote this article in 2008:
Setting Up and Using a Shooting Board
The ramp does not impart a shear cut, as he claims. The shear cut can only come from a plane with a built-in angle, as with the shooting planes by Veritas, Stanley and Lie Nielsen. All straight blade planes cut at an initial angle, but there after it is edge-on.
The fence does not, as he claims, prevent spelching (or breakout, as he calls it). What prevents spelching is technique (simply, a chamfer on the backside of the board). As soon as one uses a fence, it loses the zero clearance aspect.
Regards from Perth
Derek
