I know what you mean, I thought I had it, looked away and now it's gone again But seing as I don't have any alcoves to fit a wardrobe in, I won't need to try it yet. But I'd like to understand it.CYC":1k83o5tt said:Scrit, I am afraid I am more confused now. I think I understood it more before
Does it mean you are leaving apparent slots in the edge of carcass? I didn't think Tim said that.
Sorry if I am missing a really obvious point :roll:
Yessir! Give that man a cupie doll! The slots are indeed on the back face of the face frame and won't ever be seen. It is immaterial whether or not the face frame ends flush with the carcass side or not, the principle is the same. Maybe this will help:j":2m87y0k7 said:I think the two rows of slots are on the back of the face frame. One of the rows will be used to attach the face frame, the others will not be seen as they'll be on the back of the face frame between the carcass and the wonky wall. (they may well get cut off during the scribing process, depending on how much you cut I think.
That's why I posted the link to the base plate with the 18mm offset. It allows you to use a standard concealed hinge in a face frame with a return. You can also get riser blocks from Blum, Hettich and Salice (possibly others) to achieve the same thing or mount your base plate on a strip/piece of plywood/hardwood, etc which would allow you to utilise a cam-adjuster base plate (much easier). If there is no return (i.e. the face frame edge is flush to the inside of the carcass) then a standard concealed hinge can be used in the same way as on a frameless kitchen cabinet and you'll see the frame between doors. The base plate screws are about 37mm in from the front edge of the carcase with concealed hinges so you do have to work out your clearances carefully, which is one reason to go to lay-on (overlaid) doors with face frame hinges - they're a lot easier to hang.CYC":3khmjaxm said:I was stuck (in my head) with the use of a standard european hinge (the ones you see in all the kitchens and wardrobes around here)
so I was asking about securing those hinges to the inside of the carcass overlapping the thickness of the face frame.
Inset doors can be done using concealed hinges and are easier to adjust than butt hinges (providing you use cammed adjuster plates), but I prefer to use a butt hinge in that case - just depends on the look I'm after, really. Personal choice.CYC":3khmjaxm said:Do you always have the doors flush to the face frame?
And do you recommend having a return, why?
But you're not building an IKEA special if you're doing a built-in. So that's not the only way to go - you could just as easily add a false plinth built out from the base of the carcass like having a miniature skirting board attached - or even use skirting to match the skirting fitted in the room. Anything goes.CYC":upvduvl6 said:On common built-in wardrobes I always see the plinth recessed under the bottom self.
