Hehehe. Funny.So, trying to get myself a little more enthusiastic about routers, I decided to experiment making fielded panels with a router instead of my trusty spindle moulder. As the title say, do not do this, it’s extremely dangerous, and rather silly!
First off I need a cutter, I have a nice big panel cutter I use on my spindle moulder, it’s only 190mm in diameter, and made of aluminium so fairly light. It’s only rated at 6000RPM, and my trusty router doesn’t have speed control, so that could be interesting.
I now needed an adaptor, the cutter is designed for a 30mm shaft, but my hand router only takes 1/4”. An adaptor is required, luckily, I have a stubby spindle for my spindle moulder. It has a threaded hole on the underside that allowed me to quickly make an interface on the metal working lathe so that it would fit into the router collet. I snuggled the collet up good and tight!
The idea is to run the router on top of the work, and use shims to both space off the router (ok they will be rotating so care is needed) and to set the distance down for the cut from the top surface.
The little Elu router looked a bit small compared to the cutter block. But what the heck, in for a penny in for a pound. If you go to my thread on gate renovation you can see the results in oak. Not bad!
Remind me of model aeroplane engines tested on the bench. One false move and you lost a finger!!So first off, in the interests of Health and safety I tested it out in the bench. I sat the router in my vice, and gripped it inverted. The nice thing about the Elu is that it has a proper switch, nit ine I have to press all of the time. I was able to operate the on iff of the router from the plug. So, stood a long way away initially to check it out I texted how it would react. It sat there purring and make a nice high pitched wine.
I used Kojestia material for the interface shaft, no chance if that letting go. I don’t have much of that stuff left in my stash, but it always makes me chuckle when I’m using it.
Presumably this is to help anyone that hadn't worked out the joke yesterday?Flushed with my success from yesterday. I’m going to have a go at mounting my spindle moulder rebate block, with a top bearing to create a serious flush cutter. The advantage of the spindle block is that it has carbide disposable cutters and ‘nickers’, so none of the issues of a router cutter that creates tear out at the edges. I think the extra mass will mean it can take a good bite in one go. I intend to vary the top bearing (which I have a few) to allow me to cut door or window frame rebates. These are typically 16mm deep and around 50mm deep.
I would welcome any suggestions, help with how to do this setup as safely as possible. The cutters on this rig will be on the side, ie exposed to my midriff where as the field block had them on the top, out of the way so to speak. They are limited projection, so the sane amount of cutter exposed as any router bit.
I intend to do it hand held again.
Yes but after running that cutter as shown said testicles are currently scattered over a 10m radius.You got more b**** than I do
