paulm
IG paulm_outdoors
The refurb' of my "new" workshop is progressing well and I need to organise some lights for the sparky to fit in a few weeks time. I would do it myself but Part P and all that has put paid to most of that these days and as he is installing a consumer unit and power circuits he might as well do the lights and sign it all off I guess.
Having only used the now old fashioned fluorescent fittings in the past I'm going to use led battens on this project and thinking of these https://www.screwfix.com/p/lap-single-l ... -5ft/1079v
The workshop is 20' x 12' with an apex ceiling and will be painted white internally.
I'm thinking of two of those fittings on the ceiling ridge/apex (one front and one back), but as I don't want to be working in my own shadow at the sides of the workshop I'm thinking of having one, or possibly two, of the same units on the low part of the ceiling where it meets the side walls, so two units on the ridge and one or two on each side.
Any thoughts on whether that would be overkill on the lumens, or need some more, or better ideas on units or positioning?
I'll have additional task lights on machines as needed, but want the general lighting to be as good as possible to reduce the need for additional lamps where possible.
I've seen some of the posts on led panels, but want to keep installation simple and the weight loading on the roof structure needs to be managed too.
The sparky doesn't normally do this kind of work, only domestic CUs and wiring usually, so doesn't really have the experience to make suggestions on the lighting in the workshop setting.
Thks, Paul
Thks, Paul
