Hello Folks. Just curious to know how much grease I should add to my lathe bearings which I purchased 2nd hand? It's an older style lathe with 2 screw caps directly above each bearing. I packed them both full with a spatula but is a grease gun the best way to go? Or will the grease gradually work it's way down? They seem ok, not noisy and there's no play in the bearings but can I add too much grease or is that never an issue? Cheers
