Paul Hannaby
I'm still turning but I seem to be accumulating wood faster than I can turn it!
You should be so lucky.I'm still turning but I seem to be accumulating wood faster than I can turn it!
Yes, similar place, got everything there, but can hardly get into the shed. A clean out today I think!Hi - I turn but my shed’s a right mess at the moment and I can’t get to my lathe until my 5 year old son and I complete ‘Project Trailer’.
Never be afraid to post pictures nobody bites and it may help with any problems you may have, use it as a learning toolYup, the reason I stopped posting pictures of my stuff.
Hi,
Thanks for asking Blister. A VFD is a Variable Frequency Drive; this is the one I have; it's 3hp but can run smaller motors once the parameters are set.
Wiring in and setting up one of these VFD's can prove dangerous due to mains electricity involved where a mistake could be the last mistake ever made.
I've had my VFD for years and found initial setting up to be highly frustrating on the Jubilee lathe I had at the time but I sure had fun setting it up to run both my current lathes; I connected remote controls and had lots of problems due to "cross talk" between the signal wiring and motor wiring; in the end I used Cat 6 cable for the signal wiring to the remote controls and added switches allowing only one lathe at a time to run; I've not seen this done before so I was on my own but both lathes are now happy. Sorry I've not got wiring diagrams and I don't want to encourage anyone to have an accident.
Kind regards, Colin.
Here is one of my slimline pens. I don’t really mind anyone making comments because I believe that’s how I may be able to improve. Or I could wish to ignore. I’m not that sensitive, but I think it’s a likeable effort.
Still doing some.
Still doing some.
Thanks for that BlisterLooks good to me , Very sleek
Thanks, yes, the radial lines bit anyway!I like the 2 tone effect on the blue bowl , I assume you did that by spinning the bowl with some paint in the centre
