WoodMangler
A new word that I wish I hadn't googled - barbed wire underpants come to mind...jimi43":1tez7thg said:Apologies gentlemen if I find this akin to the woodworking equivalent of a cilice!
Cheshirechappie":1iydo7nt said:Bugbear - that's quite a good set-up, albeit using equipment that most woodworkers probably don't have.
The only thing I'd do differently is to turn the plane upside-down, and support it on three toolmaker's jacks, two at one end and one at the other. By adjusting the two jacks one can set the plane level with the surface plate cross-wise, and by then adjusting the one jack at the other end, set it level length-wise. The dial indicator can then pass over the whole plane sole surface, indicating any deviations from parallelism with the surface plate.
A note to anybody thinking about replicating Bugbear's set-up - you do need a proper surface plate - a piece of float glass or granite kitchen worksurface may be flat, or it may not. A certified surface plate WILL be flat within stated limits.
(That's a cracking photo; ghosting the plane is an excellent way of illustrating exactly what's going on.)
Inoffthered":26qf7lgj said:So Faithfull planes are cheap and cheerful then?….
How about this one then… :shock:
http://www.ebay.co.uk/itm/Faithfull-No- ... 43b2e88a49
Is the decimal point in the wrong position? :lol:
