worn thumbs
In answer to the original question;in a bit over forty years I am now on the fourth iron for my No4,the second for my No5,the third for my No 9 1/2 and the third in my flat spokeshave.I have yet to wear out a chisel.
30º is favourite mainly because it's easiest to hit by eye (gradient 1/2 up the slope, half an equilateral triangle corner, third of a right angle). 25º is arbitrary it just needs to be less than 30. But 30 is a bit shallow for narrow blades it makes them fragile so 35 ish is better, or to be precise; a bit more than 30ºbugbear":3vlmgo58 said:D_W":3vlmgo58 said:You may find old carpenters literature from stanley that suggests 25 degrees, but presume that's for carpentry and not cabinetmaking.
I've never seen that - any examples?
Most texts, from both instructors and manufacturers is pretty much 25 primary, 30 secondary.
I suppose plough iron blades are an exception, where Stanley and Record both recommend 35, single bevel.
That's about it.
BugBear
When I started up I did a lot entirely by hand (plus bandsaw for ripping) and I'd guess planing would be about 50% of the working time. Planer thicknesser is the most labour saving of all machines by far.Vann":2i5rnhdy said:Even that is very variable. I suspect that your old fashioned worker, at a bench 40 hours a week, would probably only use his No.4 and/or No.5 for 15-30 minutes a day (say 30 seconds - 30 to 60 times in a shift). ....bugbear":2i5rnhdy said:...how long would the blade of a used-the-most #4 or #5, owned by a 8 hours a day, 5 days a week, full timer last?
D_W":1be38365 said:bugbear":1be38365 said:D_W":1be38365 said:You may find old carpenters literature from stanley that suggests 25 degrees, but presume that's for carpentry and not cabinetmaking.
That's about it.
BugBear
No, I've got no source for that. I had a stanley block plane blade or plane (can't remember which) where the back of the package said to grind 25-30 and hone 30-35.
I'm recalling 25 degrees as something someone mentioned on a forum, but that doesn't mean it was ever printed. I may also be remembering that stanley has provided irons with 25 degree bevels and with 30 degree bevels. The later ones have a recommendation on the blade, right (I don't have much "later" hardware). Anyone know what grind angle was written on the irons?
bugbear":3fr79tvw said:OK, so the "carpenters literature from Stanley" thing is red herring. Thanks.
BugBear
bugbear":2i3sziny said:D_W":2i3sziny said:You may find old carpenters literature from stanley that suggests 25 degrees, but presume that's for carpentry and not cabinetmaking.
That's about it.
BugBear
