A
Anonymous
Guest
For those of you who think plane sole flatness counts, then read on
Today I had the opportunity to place a LV bench plane on a £100,000 Coordinate measuring machine (CMM) that I have been playing with.
Ran set of measurements over the entire sole. The CMM is accurate to 0.5um (half a millionth of a meter or 1/50th of a thou)
So, how flat is the sole of this LV bench plane?
Max. deviation from dead flat was +19um - that is about 0.8 thou. across the WHOLE of the sole and min deviation was -6um across the whole of the sole :shock: :shock: :shock: :shock:
1 thou is about 25um which is the upper and lower limits of error here
Decided that I don't need to hand-lap on some wet 'n' dry :lol:
Blimey, they're good!!!!
