Colin C
Alf":264nf2p7 said:A stunning argument for having a set of each, eh? :wink:
Cheers, Alf
You just cant help your self can you :roll: :wink:
The thing is I cant think of a better reason 8-[
Cheers, Alf
Nope :lol:Colin C":2mml9cff said:Alf":2mml9cff said:A stunning argument for having a set of each, eh? :wink:
Cheers, Alf
bugbear":3u7rzpgn said:Scrit":3u7rzpgn said:The obvious and maybe not quite so common exceprtion is rounds and hollows which were often offered in square bedded or skewedJake Darvall":3u7rzpgn said:Moulding planes tend to be square bedded. A profile that works off the edge has the square bedded blade naturally slicing against the grain. Its not a naturally clean cut.
Scrit
Not always a trivial choice though - the skew gives a superior cut across grain, BUT generates undesirable sideways forces.
When you trying to (e.g.) follow part of a linen fold panel, it's hard enough keeping the plane "on track" without having side forces to fight.
BugBear
Jake Darvall":6vl6xot3 said:bugbear":6vl6xot3 said:When you trying to (e.g.) follow part of a linen fold panel, it's hard enough keeping the plane "on track" without having side forces to fight.
BugBear
Oh yes. Have you tried it have ya....working a plane along an edge with a skewed blade.........the desireable skew direction in this case (working a table top edge)actually is benificial.......it draws the planes fence in tight. And because the cut tends to be far cleaner the plane is easier to control....
bugbear":39i41s46 said:I was talking specifically about using a round (or hollow) "freehand" on a complex moulding, following the layout cut (in the hallowed way...) with a plough.
The only guidance the hollow/round has is the workpiece, and if the curvature of the sole is high (i.e. quite flat) the guidance is not terribly positive, so the cut requires quite a lot of care.
Under these (specific) circumstances, the side forces from a skewed blade are not very welcome!
In other circumstances, skew blades are yummy...
https://www.ukworkshop.co.uk/forums/view ... hp?t=12106
BugBear
Jake Darvall":1hckx9om said:My apologies if I got my wires crossed.
I just assumed that be the only reasonable choice I guess.....a fenced plane.
My hat off to anyone who can leave a clean result with a non-fenced moulding plane in a groove cross grain.....regardless wheather it be skewed or not.
bugbear":26ywkg3e said:The use I mention (linen fold) is all with-the-grain work.
My point was that skewed blades are not better-without-question-in-all-circumstances.
BugBear
