A rather impractical shape - but if the box were a cylinder instead the surface area would be a lot smaller, built underground at least the base could be hemispherical even if the top would be flat to allow the gubbins to be put in and maintained.
I’m thinking an in ground system with a green house positioned on top would be a good use of the heat leakage.Finding high temp VIP's that won' melt at 500C may be an issue. I've found a German manufacturer who wrap the porous tiles in thick aluminium foil - a commercial high temp vacuum insulated panel - but it's rated maybe 100C less than I'd like it to be.
I suppose an advantage of sand is that it could be shovelled out and different patterns of air circulating tubes tried out.
Underground seems like the obvious way to go with this, but then accessibility becomes tricky, tree roots have to be worried about, heat leakage drying out our clay soil has to be worried about as I don't want to affect the foundaions of house or garage ....
The idea of something a metre thick, above ground and full height / width across the back wall of the brick garage or in a lean-to outside might be less optimised but more achievable as DIY.
Hi...here goes...I've filled a 200L geyser with mainly sea sand and a bag of riversand on the top. I've put 1 x 3kw and 1 x 4 kw element on either side of the geyser towards the top...my copper pipes run down thru the gasket plate down into the geyser say 60cm down into the sand...the elements are straight from the PV panels...3 in series but I'm not getting the soil hot enough. The element gets to 170* but when I run the pump from geyser down into the sand battery, I'm not getting the temperature I need...the geyser only goes up 2 - 4 degrees...any ideas what I can do? Thanks. Geyser is situated outside closest to the geyser location down below from the geyser in the roof.So, @Sideways and I have been mulling over making a sand battery, Sideways is a long way down the off grid self sufficient energy path and I’m seriously considering following in his foot steps. The big issue with solar is how to economically store the excess electricity and a sand battery seems a good solution.
Making and insulating the sand battery seems fairly straight forward. However, getting the heat out safely when the sand is say 200, 400 or 700C which seem to be the three max temp step points commercial ones run at is a puzzle we cannot get our heads around. Letting hot air rise out of the sand into a chamber with water pipes running through seems an obvious solution, but how do you regulate the heat such that the water doesn’t go above 80C and become dangerous steam / super heated steam and explode? Now, there may be another way of achieving the heat exchanger but we haven’t come up with anything and this sort of stuff is way outside our areas of expertise. Does anyone know a way in which it is done?
Is your geyser / tank insulated perhaps you gave heat leakage. Do you have sufficient solar panels?Hi...here goes...I've filled a 200L geyser with mainly sea sand and a bag of riversand on the top. I've put 1 x 3kw and 1 x 4 kw element on either side of the geyser towards the top...my copper pipes run down thru the gasket plate down into the geyser say 60cm down into the sand...the elements are straight from the PV panels...3 in series but I'm not getting the soil hot enough. The element gets to 170* but when I run the pump from geyser down into the sand battery, I'm not getting the temperature I need...the geyser only goes up 2 - 4 degrees...any ideas what I can do? Thanks. Geyser is situated outside closest to the geyser location down below from the geyser in the roof.
A nice idea but not easy to get it right. When I replaced some wooden steps outside my house I installed some pipes under the treads. I can circulate water around the pipes, heated by my (thermal) solar panels. My idea was to keep the steps clear of snow.The heat losses of a sand battery in the driveway would be nice for keeping the snow melted.
The water wouldn’t turn to steam if it’s a sealed system as the boiling point is raised like in a car radiator. If you fitted a relief valve then it could blow off as steam depending on the pressure setting and water temperature.So, @Sideways and I have been mulling over making a sand battery, Sideways is a long way down the off grid self sufficient energy path and I’m seriously considering following in his foot steps. The big issue with solar is how to economically store the excess electricity and a sand battery seems a good solution.
Have you looked at those hot air blowers that were used to get your fire going, Grenadier Electric Firelighter - The Easy Way To Light Your Fire or BBQThe concern is that sand has low conductivity and no convection so running the element at rated power in air will make it overheat in sand.
That would blow sand all over my living room !Have you looked at those hot air blowers that were used to get your fire going, Grenadier Electric Firelighter - The Easy Way To Light Your Fire or BBQ
This is a modern version and the one I remember as a kid had a gold crackle finish but it was a super weapon to destroy the enemy army of toy plastic soldiers.
about 3 x more than a standardish hot water tank. Mine is about 300litres.How much energy would a ibc container of water hold at 90c if you insulated it with 100mm celotex?
