Hi Brain trust,
I’m looking to build two of these book cases, or at least a variation of them. I’ve got most of the joinery etc figured out, however what I’m not sure of is the joint in the top right/left corners. I’m thinking it needs to be a joint that has some kind of inherent structure to it to prevent the 2 vertical pieces splaying outwards, however to be brutally honest I’m not confident with dovetails to attempt that many of them, and my previous efforts have been prone to a bit of “slop”.
Is there an easier joint to use? Unit is likely to be painted so final joint won’t be on show, but I’m keen to do it with hand tool/joinery rather than a drill/driver and some steel brackets (which would be a lot easier)
Hoping someone out there has some ideas other than “get better at dovetails”
