rogxwhit
To the op, Dan, feel free to improvise according to your circumstances. Consider though the inside and outside elevations and what proportions of the box are visible.
OK. I've only ever done the inside jobs. Where were you doing your sashes from the outside? They aren't common at all except regionally or in particular Georgian streets as far as I knowNot for the present circumstance, just for interest, Jacob in particular, but when the reveal has no returns (stops), at first build the box can be installed from in or out. I doubt that replacement was considered at that stage, but when the time came 100+y later it was less disruptive to plaster & decor to install the replacement from o/s. I've done many off a ladder at ground & first floor. It's only the box you have to shoulder up. That's windows of modest domestic scale.
That is an interesting interpretation of what I said. We all like to think that we are being clear and precise, when we write things down - but, alas, that isn't always the case.Not sashes - always wedged.
Yes needs a photo from the outside.Looking at the OP''s photo of the existing window, I note that the opening is quite narrow. By the time the box has been taken into account, this might well reduce the area of glass quite a lot, and hence the amount of light entering the room. I can sympathise with the Idea of putting back what was once there. And if there is a neighbours window to copy, then the OP will get exactly what he wants.
In this part of the country ( West Wales ) I have come across a type of sash window that has no boxes, weights, pulleys, or parting bead - a sort of 'poor mans sash window'. The top sash is fixed, but the bottom one is free to move up and down. In one old farm-house I worked on, the customer had replaced the plastic double-glazing with D/G wooden box sashes. These considerably reduced the amount of light in the rooms. I was only later, with hindsight, and observing other period properties, that I realised, it would have been this, less bulky, older style of window, that was once fitted.
That's interesting in the examples I've seen there was no obvious way of propping them open apart from what you suggestA few years ago I made some similar windows for a customer who was converting some farm cottages to holiday lets in Ireland.
He brought me one of the old windows to copy, it was like a sash window but no boxes which I found a bit confusing, he then produced a small lath about 4" long which he also wanted a few of making, apparently traditionally they used the lath to prop the sash open when they wanted some fresh air! Keep it simple![]()
Sounds like a good idea!That's interesting in the examples I've seen there was no obvious way of propping them open apart from what you suggest
I think the strangest ones I worked on, were a pair in a frame separated by an upright. These had pulleys and rope to the outsides only, and there were a small rollers set into the top edge of the sashes that ran along central upright To stop them jamming I suppose
I've taken out 100s of old sashes and non of them looked like they'd been built in. Too fragile - they are a bit bendy and could easily be put out of square.
As I said, inner leaf and linings holding in place. Remove all the linings and window board and the unit so be freeSash windows nearly always go in from the inside.
Whoa! Foam can pressure & distort the often thin backs, even to the point of trapping the weights. Be cautious.
