Hi all, got some advice a while ago on how to make a horizontal boarded door. Finished a few weeks ago and thought I'd show it as their a bit different. Looks really pukka in real life and its a shame that the photos don't do it justice. I made another without a sidelight as well but it was getting too dark to take a photo.
The door is 62mm thick overall. It was constructed by making a 26mm accoya frame which was domino'd together. 26mm celotex was then cut to fit between all rails and styles except where the vision panel was to go. 12mm tricoya was then stuck either side along with a 6mm english oak veener. It was then lipped all round with 10mm oak. ironmongery was a 1400mm stainless steel pull with a winkhaus automatic multi point lock and a stormgaurd cill. Finally, they were finished in sikkens filter 7 and cetol med oak.
I was supposed to use a glue press at another company to glue the doors together but it was in use so i ended up making one myself using a flat concrete floor, some 8x4 mdf and 4 half tonne bags of grain! worked a treat.
made a mistake and the first 3 WIP pics are in reverse order.
hope you all like them
