Fair enough.
Each to his own.
I've not really used them myself so I can't speak for the pros and cons.
Just wanted to make sure that anyone that does have some doesn't grind away the steel!
I don't think you need to reform the Ura very often (perhaps every 10 years or so depending on use) so it's not an everyday task!
The up side is that it should be faster to hone as you don't need to worry about secondary bevels and the back is faster to flatten.
Also, the steel is harder so it might hold an edge better.
Just going on what I've seen on the web. No idea about the reality of daily use.
I do think that they are very nice objects though (if that counts for anything).
Each to his own.
