nev":32cmv5xd said:
My tuppence worth.
Personally, I consider 100V systems for pub toilets etc (sorry Eric
) and of course going down that route that would mean changing everything and spending lots.
Wrong at several levels.
1. 100V line, done properly is capable of excellent results in practice.
I linked to Canford's own transformers. I note they have dropped their industrial quality range (as far as I could quickly see), and now only sell music quality ones. I couldn't find the spec sheet for their own brand, but the
heavy duty Cloud brand ones they sell are quoted as 35Hz-18kHz (-3dB points, whilst dissipating 100W approx.). That's quite a lot better than the practical range of most loudspeakers. Ceiling speakers? 120Hz - 12kHz, probably, and not close to flat response (OK. speakers usually aren't flat but you know what I mean).
I'm not just reading the specs either: I spent quite a while as a professional audio engineer (properly and professionally trained, I might add), both using and occasionally installing 100V line kit. Like everything, cheap == nasty, but 100V line, properly implemented, is flexible and capable of very good results.
High Fidelity? No, not by my definition, nor yours at a guess. But then arbitrarily ganging speakers and using a switchbox at low impedance kicks that one into touch immediately anyway.
100V line is certainly good enough for good quality background music, listening to the radio, whatever. Bear in mind there are hardly any sources nowadays that would stretch a genuine HiFi reproduction chain - certainly not anything broadcast, nor downloaded from the internet, nor most CDs even**. I know the world moves on, but it is unlikely that ceiling-mounted speakers are capable of sufficient quality to "reveal" deficiencies. In a double-blind test with commonly available source material could you tell the difference? Probably not.
2. It's a PASSIVE solution: no need for a replacement amp nor additional mains provision in the various rooms, hiding things in walls, etc. Suitable 100V line transformers for the speakers are only a few cubic inches, and would probably attach to the speaker itself. You could probably buy everything necessary for less than 350 quid*. One properly done mains spur for one amp could easily blow that budget if access is awkward. You don't get the Bluetooth functionality, but that wasn't in the original design spec, and anyway, it comes with the hidden cost of altering the house wiring to accommodate it. Then there's fireproofing, and the possibility of the amps failing: 100V line is inherently safe.
3. The cabling is already run: what's in the walls and ceiling is probably it. Good luck with using phono impedances over long runs in house wiring, never mind getting it in there in the first place, dealing with ground loops, etc. FWIW, I usually leave draw cords in places that have nuisance cable runs (I have four CAT5 patch panels in this property), but even I wouldn't leave one in a ceiling void I wasn't expecting to ever need to return to.
I'm not trying to pick a fight, but please don't disparage stuff unfairly.
E.
* 2x Cloud 100W driver toroidals = 84 quid
6x 20W Canford !00V line speaker xfmrs = 167
VAT = 51
Total: 302 (approx, excluding enclosure for the toroidals and carriage)
Toroidals can be in a wooden box, or whatever suits. I'd keep the QED switch (assuming it's not faulty) and use it to switch on the 100V line side.
**I have mastered a few CDs myself, I've mixed hundreds (probably thousands) of hours of broadcast material, both live and recorded, and I know of Grammy-winning stuff with shocking, rookie engineering blunders in it. You'll really struggle to find HiFi recordings these days, unless you buy from specialist record labels (on CD), or originate it yourself at 16@44/48 or 24@96. Then there's the tricky matter of finding a location to record in that's quiet enough...
