Molynoox
They look good but may be too bigWould these be useful. Placed at strategic points for weight distribution. seem to be flush fitting.
I've used similar to hang a display unit. Z Clamps,
https://amzn.eu/d/9x118ot
I think I was planning on using tape, perhaps these are too big for that though and I need a jig like you suggest.You have 2 issues to get a realy good end result
First is cutting the sides accurately to length at an angle of 30 degrees which should be OK with a track saw
Second is stopping the joints moving while gluing up. I made a jig for fitting 4mm ply splines in 45 degree mitres which are hidden when glued uo and also prevent movement so you could do the same
I think backs would look neatest set into a groove or rebate
It was my first reaction, too, when I saw the plan. All those angular sides? Not functional but, as you say, it's the OP's choice.I'll be the unheard voice of reason for a few minutes.
While you may think you have lots of room it won't be long before you don't. For that reason I urge you to adopt a more traditional design with vertical sides, perhaps a tool cabinet with the tools displayed and at hand maximizing the storage. You can still backlight it to feature the tools in it if you like.
The design you have would look great in any number of rooms in the house or even outside on the patio by the barbecue. Sometimes function is as beautiful as form. Your place so do what makes you happiest.
Are you mad?I fancy something semi functional and yet interesting to look at in my workshop
What I am thinking of doing is some hexagon themed wall units / shelves, with integrated lighting.
Here is a quick sketch I made, although I don't think I will put it on that particular wall:
for lighting I have bought some LED strips which I will somehow route behind or inside the units.
Here is a pic of the LED strip - I will probably set it to white or warm white, but I think it was set to some sort of strange blue colour in the picture (which actually looks quite interesting?...)
I think I will probably put it on the grey wall at the back
I know it isn't very pragmatic and perhaps not the best use of space, but I seem to have enough space for all my stuff so I have the freedom to get a bit creative and make it looks interesting
My questions
thanks
- How to attach it to the wall? (I'm thinking I will fasten the whole structure together and then intermittently attach to the wall through the studs - but I don't really know how?).
- Would birch ply be a good choice for material?
- How to do the lighting? - maybe hold fire on that question as I will quickly do some CAD to show the different options I'm thinking of.
- Am I mad?
Martin
Great job.I was asked to make this White Gloss panel and hang it on the wall in this alcove,.....It was spaced off the wall by about 50mm via some timber French Cleats.
I also had to find a way of fixing the Walnut veneered shelving unit to the panel before hanging the whole thing and without any visible screws/ fixings.....As you can see, I managed to do it......
The Walnut veneered material was only about 12mm thick if I remember correctly ( it was about 2 years ago I did it...)
No LED lighting though....!
SeeAnd in answer to the question in the thread title, yes, utterly bonkers!
But hey, whatever floats your boat![]()
How about this
That is a perfectly cromulent word.perpendicularity if that’s a word.
They look perfect thanksHow about using these but drilling the holes in your shelves to a depth to leave a gap at the back when pushed on:
https://amzn.eu/d/2L61kZt
Main issue is having to be quite accurate with your drilling, both in position and perpendicularity if that’s a word. See Pete’s suggestion above re position. ie make a template with card.
Also might be awkward as 12mm holes in 18mm ply doesn’t leave much wall thickness.
That actually given me some ideas....Oh no, not cats
Cats dont need a playground, they need a big dog to chase them around![]()
