HEPA Air purifier(s) for fine dust
I’m still in the “I’m not sure if I’ll like this hobby” phase of woodworking, so ideally this is a budget minded purchase.
But also don’t want to mess up my future heath because of this, so just trying to find the right balance.
I guess that me saying I’m not sure how much money I have to fund the dust collection. After some SketchUp sessions last night, the stud wall is going to cost ~£300. After that, I’m going to need to wait a bit before revisiting dust collection, but at least both the gym and workshop will be usable.
Bare in mind, if you buy a good condition used air scrubber, if you don’t end up using it, you’ll be able to sell it for mostly what you paid, so unlike a wall or buying new, you have made an investment rather than ‘spent money’.
Totally get that, and I think an air filter/scrubber is on the table at some point. I think it’s just I’m coming to the conclusion that having the workshop and gym together is a health hazard, even with the filter, so the wall is being prioritised.
Filter is certainly the next purchase though. I think my shop vac can live for a while longer with the table saw before getting a dedicated dust collector. I’ll just be more diligent blowing the saw dust out the garage door after every session.
Air particle counter arrived today. The big number is PM2.5. Accuracy is obviously as point of contention here, given it’s a brand-of-the-week Amazon model, but the LEDs (red/purple/green) on the air purifier seem to roughly match that of the counter.
The first reading with no air treatment came in 48.9µg/m3. The second reading, after using the air purifier for 10 mins, comes in at 32.2µg/m3.
Whilst neither are exemplary, the second reading matches up with what our kitchen reads, roughly. So an air quality level I’m probably happy with.
That’s not as bad as I was expecting, especially after having done some work in here earlier. The garage has a ~7mm gap under the garage door, and I’m wondering if that constant airflow is enough to clean the air to a point where it’s mildly clean (just throwing out some thoughts rather than anything concrete).
I also moved some gym weights around and what not, and that number stayed roughly the same whilst the air purifier was on.
Wondering now if keeping up on cleaning, wearing a mask whilst working, using the blower, using the air purifier/getting an air filter, is enough to keep the air quality at a reasonable place. Will have a sleep or two on it. Nice to have some peace of mind for now though.
    730.3 KB
    762.3 KB
I’m not understanding how a small air purifier is going to cope with the amount of fine dust you are going to generate.
These are domestic appliances no?
The two main ways to control dust is at source and with a secondary ‘air scrubber’
Plenty of used JET air scrubbers on ebay etc.. that have 2 or three stage filters that can filter as low as you need.
I would get the bigger model. They can recycle the air in your room in minutes (depending on the room size). In your case it could be in under a minute.
They are effective because they are very powerful and they move the air about.
These are industry standard bits of kit.
Persoanlly I’d stay away from anything branded ‘record power’.
How much dosh have you got to put on it?
The problem with these air purifiers is that really fine dust will not overcome normal air currents in a room in any location where the airspeed is less than 50 fpm. Purifiers like Record and the others do not have the power to move air at that rate more than a few inches from the air purifier itself. The only solution is to capture these tiny particles at the source and that requires lots of airflow at the tool - generally 1000 cfm. In order to get 1000 cfm at the tool, it probably requires 1200 to 1300 cfm at the extractor if there is much ducting between the dust extractor and the tool.
Turns out our continually selfish neighbours had a fire in their back garden last night that stunk up the entire street. PM2.5 counter hit 200 last night in our bedroom.
Measured the garage again this morning. I’m kinda stunned. 5.7 in the garage, with no air treatment.
But that does line up with an increase in AQ across the rest of the house after the smoke smell had disappeared.
    840.4 KB
That’s why an air scrubber is better. They move the air around keeping particles suspended and drawn into a stream towards the scrubber. Small little domestic things wouldn’t create enough air flow to do so.
Capturing all dust at source is impossible hence why even though I have a 4kw extractor, I still use an air scrubber which needs its filters blowing out once every week or two.
I have been a woodworker for 50 years. In the early days I did carpentry work for a construction company but mostly I have done it as a part time hobby. I have never smoked and I have good lung capacity at age 65. However, at the insistence of my wife, I have gotten serious about dust, as of late, and I must admit the more research I do, the more concerned I get.
I think your idea of building a wall between the workout area and your shop is a good one. Put door seals in place and it would seem you will be just fine for workouts. If you wear a good mask while working in your shop, you should be in good shape but remember the dust can persist long after you stop using the tool that made it. Depending on the tool you may need to keep the mask on a few hours afterwards (assuming you remain in your shop). The particles we must worry about are smaller than 10 microns and typically the human eye can only discern particles that are 29 microns and larger. So even though an area looks dust free, it probably isn't.
If you can afford dust extraction (rather than mask alone), go for the highest horsepower extractor (mine is 3hp) to get high flow rates and the best performing filter you can afford. Please note, I have a mid sized shop 10m x 8m so I need to install ducting and a stationary dust extractor to reach all of my machines. The more ducting, the more friction loss, thus more power required, etc. If you set up a portable dust extractor for a single machine (and thus little distance between extractor and your tool) as long as the flow rate is circa 1000 cfm at the tool you should be OK. Add a good filter (3micron or less) and you should be in good shape for a long time.
Don't be too discouraged about this subject. I must say the feeling of achievement from creating something from your own drawing to final form is incredibly fun and enjoyable. Plus you are creating something useful and growing your skills with each project. One of the things that my wife finds attractive about me is my ability to fix, repair or build almost anything. Surely, this is a far more productive way to spend spare time than watching the tube or playing video games and some women even find this an attractive quality.....
Wow!
I’m not so sure I believe it. In the gym this morning I turned off the lights and put the head torch on and could see a lot of dust in the air, where as I couldn’t see it in other parts of the house. It could still be correct, given you can’t see PM2.5 particles, but given the air is dustier, I’m not convinced the reading is accurate.
My motto is if I’m in the garage in a woodworking capacity, I have a mask on. Doesn’t really bother me having a mask on tbh, maybe COVID desensitised me.
A new issue has cropped up in that I didn’t realise how much sound is leaking out the garage door when the table saw is on. Surprised the neighbours haven’t complained. Trying to come up with a way to build this wall and isolate the noise a bit more.
I just want to enjoy building things. Currently half way through a cat bed. But keep bumping into more and more things that just make me anxious about the whole hobby.
