Sweet {Castanea Sativa]? Or Horse [Aeschelus Hippocastanum ]?Chestnut, if you can get it.
Sweet - apparently Horse chestnut is not much use for joinery.Sweet {Castanea Sativa]? Or Horse [Aeschelus Hippocastanum ]?
Iroko is not that abrasive -its quite an easy timber to machine really in terms of planing and sawingI have decent quality DIY machinery - a Makita brick-type thicknesser, Dewalt Mitre & table saws, half-decent router table and a huge Meddings pillar drill. From what everyone's said about iroko, I think I'd be changing the blades on the Makita several times, and my dust extraction is just ok.
sweet chestnut is rather like oak -its pretty tough and hardGot an email back from Wentwood re the sweet chestnut. They don't have any stock thicker than 2" sawn, but they have some 200mm x 200mm beams that they are prepared to saw to 60mm planks which would suit my 52mm finished requirement.
They also suggested white cedar - apparently it's harder than red cedar, very durable and goes a lovely silver. The downside is I'd have to season it myself.
Having read more about sweet chestnut, it seems a very nice wood for my purposes. The only downside is that the tannins tend to accelerate corrosion of any metalwork attached, and this can result in blue/black streaks in the wood. I'd also have to do all the preparation myself, since they only supply sawn.
Given all the difficulties raised about iroko, and my non-industrial machines, I must admit I'm tending more towards chestnut. Gavin at Wentwood has been very helpful in the past, and I'd be able to select the stock myself. We'll see how much the quote comes to...
Presumably this would be a sensible step for air-dried chestnut too?3) Iroko is kiln dried and is far too dry for making gates straight from the supplier -cut to rough section and put outside for a couple of weeks before making the gates
it certainly wouldnt harmPresumably this would be a sensible step for air-dried chestnut too?
+1If you are going to paint it, stick with redwood.
Does it tend to move. I've been using 18mm larch cladding recently and it's moving like a dodgy MP! But that could be due to the crazy weather!Up here in Scotland larch is a common outdoor timber (mostly cladding) and often left to go silver. I’m about to remake a small gate for the second time after my first pressure treated version rotted (got 20y painted), considering larch but I do have a big pile of pressure treated softwood left by some builders…
You could also paint the ironmongery with galvanising paint too, might help??sweet chestnut is rather like oak -its pretty tough and hard
tannins are a major benefit in preventing rot, just use stainless bolts and screws
any durable timber like iroko, western red cedar, oak, chestnut will contains tannins
Yep, or an epoxy clear-coat. I'm not going to let that put me offYou could also paint the ironmongery with galvanising paint too, might help??
If you search ‘a garden gate’ under ScottyT you’ll see on page 2 of the thread (I think) a little bit about T&G, and it’s in iroko. I explain a little on expansion, and I am sure there is a picture of my rod showing the T&G board dimensions exactly as they are to be machined with the expansion shown gaps shown.It helps immensely! Thanks for taking the trouble to answer all of my questions.
There is an obvious water trap - the trellis joinery into the middle rail:
This is how the original gate was joined, and most of the rot is in the middle rail because of it, I suspect. I'm not sure how to improve it - maybe use a small dowel or domino? Or even just pin it with a stainless steel nail from an 18g nailer without any joinery?
Re. expansion - this constantly catches me out. No matter how much I leave with pine, it always expands more. What would you recommend for 4" wide iroko T & G?
Got it - wow, that is some impressive workmanship!If you search ‘a garden gate’ under ScottyT you’ll see on page 2 of the thread (I think) a little bit about T&G, and it’s in iroko. I explain a little on expansion, and I am sure there is a picture of my rod showing the T&G board dimensions exactly as they are to be machined with the expansion shown gaps shown.
I may still go with the white cedar suggestion. I've emailed Wentwood to query whether sawing the chestnut beams into planks is likely to result in splits as the tension is released (or if the beams already contain splits). Don't really want to start with split stock.Was about to post to say if wentwood is local they often have cedar which would work well - but see they’ve already suggested and it’s been discounted.
I'm torn about this - I originally intended to reuse them. There's quite a bit of corrosion on the hinges at the front side of the gate, and also significant wear at the pivot points, but nothing that couldn't be fixed by a bead of weld and a file.Can the existing hinges not be reused? Finding replacements may take longer than putting a wire brush in an angle grinder, stripping them then base coat and topcoat.
What are you using it for? I’ve not used it (yet) but I believe from my local supplier that larch cladding is generally unseasoned. The normal batten-on-board cladding method allows for plenty of movement but for joinery you’d need seasoned.Does it tend to move. I've been using 18mm larch cladding recently and it's moving like a dodgy MP! But that could be due to the crazy weather!
