Probably 1/4 but could be UNF, UNC or Whitworth. Be careful of the latter two as they have the same pitch, but a different thread profile. Hopefully someone on here will know.
Lots of different designs kicking about. Basically either to tighten on to the workpiece or to expand into a recess in it, such as a bowl bottom. Other add-ons possible.One the things that came with this lathe is what I think I've identified as a collet chuck, albeit only with one set of (4) jaws.
It was seized up solid, and after soaking in white spirit and two-stroke oil to no avail, I resorted to heat, and finally got it working.
I presume the strategy is to turn a short tenon of the right diameter on the end of the workpiece by other means, and then fit the collet chuck. Is that about right?
Cheap enough to get one each of UNC and Whit and compare with the original. The angle of the thread is 55° on one and 60 on the other. Not easy to tell them apart but offer up a new one against the old, provided it's not too worn, and it will be apparent which is correct. Lots of British companies were still using Whitworth threads, particularly on machine tools and similar stuff. You need to get it right as on a short thread the wrong one may go in, but you will damage the thread. Alternatively if you have any metal working pals who have thread cutting tools or chasers, then they will tell them apart.I've done some measurements, and believe it to be 1/4" UNC. Although Whitworth is very similar, I can't imagine Arundel using Whitworth.
Thanks, I'll file that away. I actually found one on Amazon for 4.88 including postage, which should be here today.https://drivebeltsolutions.co.uk/
are excellent for belts.
edit - I often get two belts at a time, the P&P often being as much as the belt. Belt and braces ...
Yes it is - I thought you were talking of the plate covering the sealed bearings, seen on other models.Mine is(was) blue, and here is a bad picture (it's in pieces right now). The disc on the left of the headstock is what I thought was an outboard face plate, as it screws on with a lh thread, and has two sets of three holes in it.
I think it is Whitworth. My neighbour found what he thought was a 1/4" Whitworth screw, but it feels very loose, so I'm guessing it(my neighbour's screw) might be UNC, as I found something on the web to that effect.Cheap enough to get one each of UNC and Whit and compare with the original. The angle of the thread is 55° on one and 60 on the other. Not easy to tell them apart but offer up a new one against the old, provided it's not too worn, and it will be apparent which is correct. Lots of British companies were still using Whitworth threads, particularly on machine tools and similar stuff. You need to get it right as on a short thread the wrong one may go in, but you will damage the thread. Alternatively if you have any metal working pals who have thread cutting tools or chasers, then they will tell them apart.
Decide on size, screw on a disc of MFC and buy some stick-on velcro backing. It sticks well to the smooth surface. Widely available e.g.; VELCRO® Brand VEL-LOC® 175mm x 500mm PS18 Adhesive - For Sanding Pad ReplacementI seem to remember some talk about this on here before, but I'm contemplating using the outboard face plate to make a disc sander, for tool grinding, amongst other things. Any advice welcomed in this regard, and also any pointers on velcro type backing.
I know this might seem like running before walking, but I'm merely trying to get my head round where to mount this lathe in my rather small workspace.
Thanks. Could I use the other side of the MDF disc for autosol?Decide on size, screw on a disc of MFC and buy some stick-on velcro backing. It sticks well to the smooth surface. Widely available e.g.; VELCRO® Brand VEL-LOC® 175mm x 500mm PS18 Adhesive - For Sanding Pad Replacement
Also handy is a disc of plain MDF with autosol or similar - for almost instant high polish of cutting bevels.
Shape the edge of the disc to half round etc to polish inside of gouges
I keep meaning to get hold of a cheap old wrecked lathe headstock just to make a sharpening/polishing station
MFC for shiny surface to hold stick-on velcro padsThanks. Could I use the other side of the MDF disc for autosol?
Ah! Read it too quickly...MFC for shiny surface to hold stick-on velcro pads
MDF for more absorbent surface which holds the autosol or Brasso etc. You don't have to add it every time.
Whitworth have threads at 55 degrees, UNC are 60. Most sizes have the same tpi.I think it is Whitworth. My neighbour found what he thought was a 1/4" Whitworth screw, but it feels very loose, so I'm guessing it(my neighbour's screw) might be UNC, as I found something on the web to that effect.
I suppose it makes sense to be Whitworth, I hadn't realised before that UNC was more of a USA thing.
Getting the right chuck, plus adaptor if necessary, should be no prob. What chuck for Arundel j4 junior m24x2.5 spindle?Thanks. My problem is that my neighbour believes the sample screw he gave me is BSW, but since it came out of a box of random bits and pieces, there's no guarantee. Thus the fact that it's loose leads me to the conclusion that the pulley block is BSW, and my neighbour's screw is not. From my perspective, I can imagine that I'm going to sell this machine on at some point, as I doubt I'll ever be able to find chucks for it at a sensible price( the internet doesn't even agree on the headstock thread), so the less I spend on it the better.
