I've got a sliding table saw (for ripping 10ft sheets) and also a normal fence. A while back I noticed it wasn't cutting very well so got out a micrometer thingy and first rotated the saw so it was in line with the sliding carriage then adjusted the fence so it was slightly wider as the wood exited.
My question is should I really have set the saw bang on parallel? (Front and back of blade) Using the sliding carriage, as the wood enters the saw blade it cuts beautifully but as soon as the wood touches the back of the blade it begins scorching- somethings obviously moved. I'm gonna remove the carriage and have a good butchers to see what might have moved (blades all fitted nice and clean) but am not too sure how much clearance, if any I should have on the fence/carriage.
I've got some 4 inch thick treads that need cutting for length so it'd be good if I didn't need to do too much to the ends.
Coley
Sent from my SM-G900F using Tapatalk
Coley
