Bemused":b066zoyq said:David, if your short on time you could thin out some varnish maybe, make it real thin like water.
If your anywhere near M6 J16 I could sort you out...
L2wis":27f9u9mq said:I'm not speaking from experience but I can't see how it would affect lathe bearings anymore than someone just sanding by hand.
From what I've read a sanding sealer is used before sanding. I believe the sanding sealer stops your finish from being absorbed into the wood through the grain by blocking the pores, maybe thats why the chap told you about that usage?
*Edit: I didn't realise there was a second page of advice
Davidf":1xferji0 said:L2wis":1xferji0 said:I'm not speaking from experience but I can't see how it would affect lathe bearings anymore than someone just sanding by hand.
I'm not sure, he seemed perplexed about the idea of using it as suggested here, insisting it was used AFTER sanding.
I think the argument over the bearings is not a very valid one as you say. If you were going to put alot of pressure on maybe.
Well, i ve been thinking over this whislt doing my "nights".....I'm going to grab some sleep now (7.45am just got in) ......sort out my sand paper thats arrived and see whether the situation can be improved at all.
jumps":3id9thh9 said:Davidf":3id9thh9 said:L2wis":3id9thh9 said:I'm not speaking from experience but I can't see how it would affect lathe bearings anymore than someone just sanding by hand.
whilst it's been said before in the thread, sanding sealer is primarily used after final sanding, then de-nibbed and chosen finish applied.
it is however extremely useful to harden soft woods, or wood fibres, prior to sanding...
you really shouldn't be using any pressure when sanding on a lathe - you want the paper cutting, you don't want it clogging or building up heat - both of which are more likely as pressure increases. equally lathes should be on a slow speed for sanding.
fresh/new abrasives will of course work so much better (ie properly), just as any freshly sharpenned tools!
jumps":287iiani said:Davidf":287iiani said:L2wis":287iiani said:I'm not speaking from experience but I can't see how it would affect lathe bearings anymore than someone just sanding by hand.
