Well, my life came to a point where i want to change my hobby (and career?).
But for that i need a workshop.
I'm running on no budget at all so for now i have set my goal to put a frame up, wind/rain proof, so i can later build up little by little. Just cant afford to do this "properly" at this time.
Already put a good concrete slab foundation, 6x4m (20x13ft).
Plan is to erect timber frame (2"x4") with single slope roof, 2.4m on high side, 2.3m on low side, inside. Is the 100mm drop over 5m enough ? 5m because i'll leave front overhanging by about 750mm. Roof beams 2"x8", put on edge for more support, spanning entire width of 4m between front and back walls.
I already have skip dove for 3x windows (1190x1510mm frame) and 1x doors (890x2080mm frame), pvc doubleglazed. Putting pvc door for walking in and probably another door (wider/double) to be used for bigger things coming in and out of the shop.
Will cover in corrugated metal cladding, roof partially in translucent plastic corrugated to let more light in.
To be honest i dont know what i'm doing. I havent a first clue about framing, need tips to efficiently design this not to burn thru too much of timber. Also, i need the design so it can be built in phases, cant build everything at once. Meaning, framing/weatherproof/windows/doors first, then floor, then insulation/electrics, then finishing.
Since i'm of IT/Cad/Graphics background i'm playing about with sketchup trying to figure things out as i go...
Will post my first concepts for critique.
Reading lots of stuff, but i like "live support"
At this very moment i need help with framing, saving as much wood as possible without compromising structure.
Any takers for an online apprentice carpenter ?
P.S. Did i tell you i dont know what i'm doing ?
