Adam Pinson
Hi,
I have a Union Graduate lathe with 1 1/2" x 6TPI nose and opted for the Sorby Patriot chuck with just the standard set of jaws to start with but these jaws so far have done all I want. The patriot fits my lathe with a Exert.
Robert Sorby Patriot Chuck Inserts and Exerts, Robert Sorby Patriot Chucks and Jaws, Robert Sorby Woodturning, Carving, Woodworking on Westcountry Machinery 4 Wood
Patriot Chuck System
I fully agree with marcros in saying don't go mad buying extra chuck jaws unless really needed. I bought my Patriot direct from Sorby's in Sheffield collecting it but later found I could have bought it cheaper at Turners Retreat with free postage; shame on Sorby's for treating me like this.
I like the Patriot though; if I were to buy all the extras I'd need a second mortgage so until needed I'll stick with the one set of jaws it came with.
Lathe attachments often end up costing more than paid for the lathe and in the case of expensive chucks these are relatively new compared to the old methods of securing work in a lathe. I often use "jam chucks" I like these because I can make them cheaply from offcuts I have kicking around to any size; yes they do have to be made taking time but I don't mind because I like working on the lathe; here's a sample video which demonstrates alternative ways of chucking;
Kind regards, Colin.
Another way of chucking small items is to use collets with a draw bar; I turn the blanks as in these finials to fit the collet at one end allowing the finial to be completed in one go.
A quick way to achieve the correct diameter for a collet is to use a spanner as a gauge.
My Graduate doubles up as a metal spinning lathe so here is a friction drive; the spun aluminium seen lower down.
When I turn a lot of identical diameters I rig up a simple hinged bar like this seen in action; very simple to make costing nothing from offcuts but accurate; here is one of a batch of finial blanks being turned between centers and will then be finish turned in a collet.
Two aluminium spun light reflectors using the former shown in previous picture on friction drive but I'm only adding these two metal spinning pictures just to show what can be achieved on a lathe assuming the lathe has enough power.
Here's a wooden jam chuck being used in combination with the Patriot chuck; I'm about to withdraw the tailstock allowing the bottom to be cleanly finished. I derive a great deal of pleasure just playing on the lathe and I'm only limited by my imagination; there are often a number of ways to turn so I've added these for novices new to wood turning. I hope they are of interest.
What is the purpose of the extention in front of your chuck? Would it help stop my chuck and faceplate binding to my headstock ?
