narrowboater
Rob
Bet you got a fast shave, if not a long one.
Regards
Rod
Regards
Rod
narrowboater":2n7gdk4j said:A builder friend of mine used to use a 240V angle grinder running of 110V through a transformer, to reduce the speed when cleaning out mortar for repointing brick work, This could, I stress could, be an answer for people who want a slow speed grinder.
It would also solve the problem mentioned above and give you the advantage of effectively having both a high speed and slow speed grinder. The problem being of course that you need a fairly chunky transformer.
I don't know if this a possibility, but I thought it was worth a post.
...Rod
