Is is possible to colour stainless steel in the home workshop, ie using a propane or mapp gas blow torch? I want to achieve a blue colour, similar to the image. I need two pieces to be similar, the actual colour isn't vital.
material will be 40mm stainless steel pipe, 50mm long, wall thickness 3mm.
how resilient/stable is the finish to scratches and handling?
the only proper of stainless steel that I need is the lack of corrosion (generally, and in the presence of dry table salt) and lack of staining to oak.
