Head torch recommendations?
Jacob
What goes around comes around.
7 Jul 2010
Derbyshire
Dozens of options, Screwfix, Toolstation etc - any recommendations? for a head torch, for working in dark corners, unlit cellar etc. Also for cycling as extra light, rain proof?
Fenix are supposed to be really good, but should be at the price.
For work we use the Unilite ones slightly cheaper but also very good.
There is an outfit called Torchdirect, they have more torches than you could shake a stike at.
If you use these for a length of time on a job at arms length your eyes adapt and you don't need them specially bright. Something lightweight like the old Petzl Tikka was good for this.
If you use them for (eg) night hiking where you want to light up some distance ahead then powerful is good and that probably means one with the light at the front and the battery in a box at the back to balance the weight.
They are handy in the right place, essential for outdoor sports, but for task lights I've become a fan of the Unilite CRI range of rechargeable LED lamps and haven't used a head torch in a long while.
Have you seen the Big Larry lights by Nebo ? Cheap and handy with a magnet in the bottom.
Look for ones that take the large 18650 rechargable battery, my Fennix takes a Nitecore 3400 mAh one and it last reasonably well. It is this one which is now discontinued
https://www.fenixlighting.com/products/hp12-fenix-headlamp
You will find that having one with the battery at the back and not within the actual front light is more comfortable, spreads the weight better.
If I was replacing it then I would look at something along similar lines, maybe not having a removable battery because it would not be for caving or hiking where carrying spare batteries is essential.
Fenix lights are decently made and not bad value. Far better than "LED Lenser" for example.
Can you expand on that? What is it about LED Lenser that you dislike? I have a LED Lenser head torch that performs well, but I don't like it even though I cannot put my finger on why not. Maybe it is the custom charging cable that I can never find when I need it.
I much prefer my Suprabeam M6XR. Not that I would ever buy that for myself, but having got it for nothing (my wife received it as a gift and I purloined it) I do like it and use it a lot. Although the charging on that is not convenient either: you have to remove the battery from the case and plug the charging lead directly into the battery.
I have three old Surefire lights (E2, C2 and C3) all with high quality aftermarket LED modules.
They are excellent. The C3 once sat in a pint pot pointing at the ceiling and lit up an entire rural restaurant during an hour long power cut so that service was able to carry on :)
I own one Fenix that I bought years ago for my daughter to take on a two month project Raleigh trip to Nicaragua. I wanted reliable, AA batteries that she might buy locally and cheap enough to lose. That little light has a great spot beam, super solid build and not a bad colour tint. It now lives in my toolbag.
LED lenser are not bad lights, they just aren't as well built, don't have the same beam tint and quality and you can get better for the money.
I bought one of these to try....
def getting another one....
rechargeable exc light even the spot light is good....paid just over £8.....
As a caver, I have used the Fenix HL55 for a fair few years now and it has given me faultless service. It is now discontinued and been superceded but I wouldn't hesitate to replace it with another Fenix if needed. You must remember, that if going for a headtorch that uses an 18650 battery, that you will need to purchase a good rechargeable one of these and that can add £20 to the cost (don't buy cheap, they can actually be dangerous) and a charger to charge it (again, don't buy cheap). Unless you need it for more specialised pursuits such as caving, I would look at the cheaper options out there. If just wanting to get into the odd dark corner and not wanting range or floodlighting, then cheap, less powerful ones are adequate. For cycling, I expect you would want a pretty powerful one. Mine puts out 420 lumens on high with 900 lumens on a short burst mode. Newer models will provide higher outputs.
Have a search through this forum: https://ukcaving.com/board/index.php?forums/equipment.8/ There should be a fair few threads from people asking for recommendations as well as discussion about batteries.
Thanks for suggestions. Spoilt for choice! Took pot luck and went for LEDlenser iH5R on special offer from Screwfix. Seems just the job. Rechargeable by USB connection or by swapping battery.
Ive got an led lenser and im happy with it. Ive also got 3 handheld led lenser torches. I dropped one off a scaffold and it broke (something internal / on the battery carriage ) i asked lenser to sell me a replacement carriage. They refused and insisted i send it in for repair.
A week later it arrived back, fixed, free of charge.
Ive got a couple of the cheap luceco ones on offer in screwfix, 8 quid, rechargeable. So far so good for the money.
I nearly bought a nebo headtorch in jewsons but looking at the packet, it has a 30 SECONDS battery life at full power 😆 mind you, it was tiny
Ive also got a red energiser one, works well too.
I can actually help with this one as I use them for a living and have tried a fair few different types. Unless for a very specific application (ie cave diving etc) I would recommend Petzl. I have found them utterly reliable in some absolutely appalling conditions. Personally I use the Tactikka but they have a large range so there will be something that suits!
I need this for cycling on our local lanes
Actually illegal to ride with light on your head a light on a Public highway! apart from dam dangerous if only light! you turn head/look elsewhere etc and whoop no light shown at front also if you approach anything on road the brain doesn't register your light as just up in the air as light beam can be anywhere from feet to miles as a beam with no substance and it's seen when lights up something like front wheel ground in front or something you can judge distance from.
