Sawdust":1lssb2n5 said:
Regarding the comments about CE marking. We get our products at work (completely unrelated to woodwork) CE marked and my understanding is that it is an electrical safety and interference check so I don't see how it is applicable to whether or not a dado is dangerous.
Mike
Interesting. The concensus so far on here is the CE marking is to protect the user. Although in general, thats correct, at my last employer we used it to protect us. From lawsuits.
Firstly, to get a CE mark you need to determine which EU legislation is applicable to your product. That in itself is a specialist area and often sub-contracted. If you were a manufacturer of table saws, you could argue that table saw legislation was not applicable (for some bizarre reason, say, becuase your saws are intended as toys for children) and you should be tested against the requirements for say, childrens toys. In court however, it would be hard to justify not being complaint with table saw legislation. If someone had chopped there hand off, they would have a much stronger legal case against you.
So, the first aspect of CE marking is to be tested against the regulations appropriate for your product.
Then the testing, again, although you can do this in house for many aspects, but how well would that stand up legally in court. Is your equipment calibrated? Personnel trained? My product was a wireless product, and hence could (potentially) interfere with pacemakers, communications between ambulances, and with your phone lines etc etc etc. Having it tested externally provides a much more "rigorous" proof, that you are inline with any relevent regulations. Of course I tested it internally, but its a back covering exercise. What happens when its struck by lightening, what happens if it burns...
Anyone / company can import a non-compliant saw or other item, and put a "CE" mark on it - sure it may be meaningless to some, but at the point you recieve an injury, and wish to sue, then it becomes a much more useful piece of legislation. The company could end up in court, and if, as mentioned, there is no folder of evidence / testing then they are most likely going to end up with a very big claim.
As Andy mentioned (for most products actually), I think inches and inches of paperwork is the minimum level of evidence needed to demonstate you comply with all regulations.
Of course, going back to the actual question, it seems Devon knows about using a router, he has a router, but he wants to extend the arbour to put a dado blade on. Why are we telling him to use a router? He knows already. Devon, could you get a parts list for your "cloned" type saw and see if the arbour could be removed and replaced with a longer one, even if it meant one of your Australian friends purchasing one and sending it over to you?
Adam
