I’m turning a pestle and mortar on the lathe using some Scots pine logs I acquired and was wondering what the hardest surface finish I can produce so grinding can be done at the bottom of the bowl.
To be more precise I’m wondering if buffed cellulose sealer would be harder or softer than cured Danish oil. Pine is not that hard so I need to make up for it in the finish.
Any thoughts on the most appropriate finish would be appreciated.
