Happy Bloody 2013
Not to hijack the thad and turn it into iTunes support, but which iPods are they, just out of interest? Which version of iTunes are you using, and on which OS? What should happen when you plug in your iPod is that iTunes should sync all you music, movies, apps etc... as per your preferences, but sometimes (iTunes for windows particularly) the 'sync music' option can become unchecked. With your iPod connected, take a look at the 'Summary' tab in iTunes - is the 'manage my music manually' option ticked? This would prevent your music syncing automatically.
Incidentally, you can only sync an iPod to one iTunes library at a time (anti-piracy measure) so if your son synced his with a friends laptop, he should get warning message when he connects it to another library (e.g. yours) that it will be treated as a new device I.e. be wiped clean and synced with thre current library.
If it's an iPod Touch, you can force a restart by holding down the home and power buttons together until you see an Apple logo on the screen - ignore thre red 'slide to switch off' button - which is sometimes worthwhile if you're having issues; it's a small computer, and the occasional restart doesn't hurt. Failing that you can restore it to factory defaults in iTunes and start again...
FWIW we run a large iTunes library on both Windows and OS X (many devices syncing with several different libraries) and have never had these sort of issues with a new device. My 9-year old nephew successfully set up a new iPod Touch at Christmas without any help, and my 88-year old father did the same with an iPad Mini and an iPhone, again without any help or support - just as well as he's a couple of hundred miles away! My point being, that most of the time you plug these things in and they work - let us know how you get on, or if any of the above helps.
Cheers, Pete
Cheers, Pete
feel free, Pete. Im not au fait enough with syncing as I don't do it.
Hi Pete and Roger,
Thank you for the tips. They are iPod Touch 4, onto iTunes latest version, on a laptop running Windows XP Pro. The friend's is similar, but running Win 7.
I will ask the friend to 'de-authorise' my son's device and see if that helps. (But only after I've had a bit of me-time in the shed :cry: )
The settings on my PC are correct, as you describe, (and work perfectly now with daughter's iPod, which has only been sync-ed with this PC).
I will update here when tried above steps.
Greg
Wouldn't expect it to make a difference tbh, but no harm in asking. Incidentally, did you say that you'd bought more than one iPT? Are they both displaying the same behaviour?
Personally, I'd do a restart (as described above) followed by a full restore from iTunes.
Keep us posted.
Pete.
Yeah... Ruddy 2013.
I just had news I have to go into the 'Kranken-Hause' for another knee replacement in February. That's okay; but the bad news was I have put on a stone over the holiday!
And there was me thinking all that chocolate, rum & coca-cola,fruit cake and Christmas Pudding wouldn't make much difference in the bigger scheme of things! How wrong can we be? :mrgreen:
Keep us posted.
Pete.
Hi Pete
No - only not working with the one that was sync-ed elsewhere.
Greg
gregmcateer":pm6ct32l said:
Good luck with the bionic knee, John - Hope it's successful.
and remember to keep off the pies!
Thanks Greg.
As the guy doing the op, is the one who did my other knee, then I have every confidence.
I'll do my best to keep off the pies, but the NHS have decided to send me into a private hospital for this one. They even showed me the type of ward I will be staying in! (En suite!) I just hope the food is good. :D
As long as I am down by 20lbs, I'll be admitted. 8)
