stuart little
There are 90° brackets with flange fitting to wall available.
They are what I am trying to avoid.There are 90° brackets with flange fitting to wall available.
Yup, load distributed over three cylinders not one and removes the alignment issue of the bracket having to be in/out from the wall by the pitch of the screw thread, terrible design, no wonder it’s hard to buy them… but I get the impression a mind is rather made upThe types used in the UK, if installed with correct length and size screws do work fine. The one installed when our then council home was built has never shown even the slightest suggestion of movement or whatever. Likewise a second one installed (again three screws plate system) on the opposite wall, to help my Mum use the stairs more safely as she grew frail, never showed any signs of failure either.
...issue of the bracket having to be in/out from the wall by the pitch of the screw thread...
It seems that you didn't (think it through) - That would mean that the bracket would be upside down !! @TheTiddles is correct, it has to be the full pitch.Think it through and you will see that the maximum difference would be half the pitch of the thread.
Hi
Apologies for my Victor Meldrew approach last time, you were correct that I didn't fully read your post, I just jumped in thinking I can help here and I found that Supplier took a screenshot and posted it.View attachment 165659
In future I will fully read any post I respond to.
Again I'm very sorry and hope you let me off for being rude and disrespectful to you.
Anyway, I noticed in your last post that you have wooden posts and also it's on a curve.
I just wrote a very very long post ready to send then realised I wasn't logged in - logged in and all my words of wisdom disappeared !
So this a condensed version -
Have thought about a rope handrail which can be surprisingly strong.
This would eliminate the need for lag/handrail brackets altogether, they very often seem to work loose anyway, either the wall/post fixing or the upward fixing into the handrail.
Lots of options with rope where no brackets required whatsoever - drill hole through the post and put a screw through the rope to hold taught once happy with position etc.
Drill through and wrap around post and onto next post etc.
Just wrap around and move on.
I've attached pictures etc of different brackets if you do want to use them.
Rope can be natural hemp or synthetic and I think a good size is around 40mm thick for grip. I believe the synthetic is less prone to the rigours of the rain/weather.
I presume you are intending put a timber handrail on the brackets you are looking at - as I'm sure you know, timber handrail around a curve whether up and down or literally around a corner can be a time consuming event as the joints always seem to be a different angle to set unless everything is perfect which it very seldom is !
I have fitted several "rope handrails" in nursing home gardens/grounds and they work well and seamlesslyView attachment 165656View attachment 165657View attachment 165658 blend in with the surroundings well.
Sometimes in a handrail it's the reassurance that it's there that's needed.
Anyway, please forgive for my previous horribleness (made up word I think, but fits) and I hope this post finds everyone well !
P.S - my attachments seem to have attached in random places on here, don't know why
Hi MikeJhn@okeydokey Thanks for the link, they are in Australia, however, I am fixed up know, believe it or not found some locally, but thanks for looking.
Something like this?Following on a bit from this, the handrails will be joined together with Zipbolts at various angles, as this is external I am thinking of adhering the two together with a polyester glue rather than a PVA what would other use?
That video shows a Zipbolt by a different manufacturer which is what I am using, the polyester glue is just to waterproof the end of the rail, I know that Epoxy would be better, but I already have some pine coloured Polyester resin, thanks for the thought.
Already have our handrail supports, if you look back on the thread it was discussed at length and eventually I found some locallyThe round cover is a push fit covering the screws. They can be fitted at any angle and are maintenance free.
Kind regards, Colin.
Doubles the number of posts!OR maybe better still don't join the rails leave a deliberate gap and ensure the fixing brackets are placed nearish the end of each length of rail.
