Hi Karl,
I've been doing some more planing this morning (seem to do nothing else these days :roll: ) so I've been giving your question a bit more thought.
The first point to make is, forget any romantic notions which you may have about doing everything by hand. People will talk about the Barnsley Workshop doing everything by hand until the 1950s and that sort of thing, but there's nothing romantic about it. It's hard work and your productivity will be quite low DAMHIKT
Stock preparation is all about working efficiently and getting the job done as quickly and effortlessly as possible.
I do everything by hand only because I can't afford machinery at the moment. I love planing but even I get fed up with it some days.
My experience is that you need several planes set up for specific tasks. Whether you use wood or metal planes isn't an issue. I prefer metal, some prefer wood - it's a personal thing. The real issue is how you shape the blade and how long the planes are.
I have three planes set up as scrubs with heavily cambered blades. One is the size of a #3, then there's my #5.5 and my #7. I will use whichever one is best for the wood I'm planing, or maybe all three on the one piece of wood, it just depends. The point about a heavily cambered blade is that as you are using only the central portion of it, it offers little resistance. You can therefore plane off thick shavings even in stuff like rough, sawn oak. But I also use them to take fine cuts. As I say it all depends.
I then have a #4 and a #5 with slightly cambered blades.
I then have my "best" planes - Cliftons #3, #4.5, #6 and #7 with straight blades for finishing work. I really like them
The point I'm trying to make is that no one plane is "best" for everything. They all have their purposes. However, if you get into stock preparation by hand you will soon find what works and what doesn't. You have to or you'll simply give up because it's hard work.
Hope some of this helps.
Cheers :wink:
Paul
PS make sure your blades are sharp :wink: :wink:
