I've always been doubtful that squeezing a chip between the jaws of a set of machinist's calipers would give an objectively accurate measurement or a consistent measurement from chip to chip. I guess those who developed such a skill are to be congratulated. Otherwise, even the rankest of beginners or even a non-woodworker can tell the difference between varying degrees of thick shavings and vanishingly thin shavings by eye. It's like asking for a big piece of pie vs. a little piece of pie. It's not too hard to tell the difference. I wonder if Alan Peters ever measured the thickness of a chip his entire career. I bet not. If so it was probably on a lark or a quittin' time diversion.
Woodworkers need to be able to judge things by eye or get very close -- edges square to face, face in or out of twist, etc., etc. Measuring chips just promotes dependence on measuring tools too much IMO or the notion that one needs to attempt to measure very small increments rather than using standard terminology like 'bare' and 'full' which should be enough.
It's just not a terribly difficult concept, that of retracting a cutter until it won't cut and then advancing it a little at a time until it just barely starts to cut, and then moving on from there. My seven year old daughter has virtually zero problem with the concept. It's like running a bath at the proper temperature -- not that hard -- but you usually have to fiddle with the hot and cold a bit before it's just right. It would be idiotic to stick a thermometer in the water when your hand tells you all you need to know.
